Cummins12V98
Nov 18, 2021Explorer III
Rollochrome wrote:Cummins12V98 wrote:
You are well under temps that would be of concern.
Does your axle weights require the MAX of 110# ?
gawr 7,000 LB each axle
gvwr 15,500
You need to know your actual loaded axle weights. One you do compare to the load/inflation chart specifically for your tire size and load range.
I am betting you are running too much air.
About Fifth Wheel Group
