JRscooby
Nov 19, 2021Explorer II
Cummins12V98 wrote:
Over/under MAX has nothing to do with "PROPER" inflation. There is a reason for every tire there is a Load/Inflation chart.
Weigh your axles and add 5psi to what the chart recommends. This is per GY Tech support for when a person wants to use the brain GOD has given you instead of blindly airing to MAX sidewall pressure.
LOL. "Proper inflation"? Weigh axle, check chart. If the tires on the axle are equally loaded, that 5 lbs is over inflation. OTOH, if you have a 30/70 split, you could still have a tire underinflated.
About Fifth Wheel Group
