MFL
Nov 21, 2021Nomad II
fj12ryder wrote:
If I ran my old trailer with tires at the max, I would have the capacity for nearly 24,000 lbs. on the triple axle. Having weighed the trailer, I knew I had barely 15,000 lbs. on those six tires. Absolutely no reason to run max pressure, and suffer the resultant rough ride.
Since a triple axle adds a lot of capacity to a trailer, I am just curious, if your previous trailer came with those tires rated to carry 24K. Did you upgrade from the OEM tires listed on the TH placard on the driver's side front?
Anyway, JIMNLIN, ^^^ and I are on the same page, when considering a RV trailer, outfitted with the proper ST tire.
Jerry
About Fifth Wheel Group
