fj12ryder
Nov 21, 2021Explorer III
MFL wrote:Jerry, the Fuzion came with 235/85-16, E-rated ST tires. Which were, I believe, rated for around 3,480 lbs., so the original tires were rated for about 21,000 lbs., still over the GVWR, and waaaay over my actual weight of 15,000 lbs. I actually considered going to LT tires when I had to replace those lousy ST tires. But the Sailun tires were cheaper than any of the other LT tires at the time.fj12ryder wrote:
If I ran my old trailer with tires at the max, I would have the capacity for nearly 24,000 lbs. on the triple axle. Having weighed the trailer, I knew I had barely 15,000 lbs. on those six tires. Absolutely no reason to run max pressure, and suffer the resultant rough ride.
Since a triple axle adds a lot of capacity to a trailer, I am just curious, if your previous trailer came with those tires rated to carry 24K. Did you upgrade from the OEM tires listed on the TH placard on the driver's side front?
Anyway, JIMNLIN, ^^^ and I are on the same page, when considering a RV trailer, outfitted with the proper ST tire.
Jerry
I ran the OEM ST tires at 80 psi, max sidewall recommended pressure, and they failed in less than 2 years and 6,000 miles. The sidewalls were like tissue paper, they were so flimsy.
About Fifth Wheel Group
