Walaby
Nov 21, 2021Explorer II
Cummins12V98 wrote:
Over/under MAX has nothing to do with "PROPER" inflation. There is a reason for every tire there is a Load/Inflation chart.
Weigh your axles and add 5psi to what the chart recommends. This is per GY Tech support for when a person wants to use the brain GOD has given you instead of blindly airing to MAX sidewall pressure.
Im just curious.... if the chart is gospel, why go 5psi above what the chart recommends?
Mike
About Fifth Wheel Group
