Eyetattoo
Jul 05, 2013Explorer
Max rim PSI
I noticed that my rims have a max PSI of 65 lbs but I have always run at 70-75 psi with Maxxis Load E tires. I run at 70 psi because the trailer has a max weight of 11k lbs. Should I be concerned ab...
Eyetattoo wrote:
I noticed that my rims have a max PSI of 65 lbs but I have always run at 70-75 psi with Maxxis Load E tires. I run at 70 psi because the trailer has a max weight of 11k lbs. Should I be concerned about what is stamped on the rim? I would really like to run them at 80psi......
