EyetattooExplorerJul 05, 2013Max rim PSII noticed that my rims have a max PSI of 65 lbs but I have always run at 70-75 psi with Maxxis Load E tires. I run at 70 psi because the trailer has a max weight of 11k lbs. Should I be concerned ab...Show More
EyetattooExplorerJul 05, 2013So if I run them at 65 psi will that cause any tire heat issues on the E rated tire?
Related ContentRim max PSImax tire psi vs door panel max load psiE rated tire with max psi of 65?Max PSI rating on Trailer Wheels?PSI
