I noticed that my rims have a max PSI of 65 lbs but I have always run at 70-75 psi with Maxxis Load E tires. I run at 70 psi because the trailer has a max weight of 11k lbs. Should I be concerned ab...
I've seen folks WAY overload tires also. Doesn't make it safe. You are certainly more of a gambler than I am, running rims at 80 psi is a TWENTY THREE PERCENT OVERLOAD. Hope when a wheel blows we are not near you, you scare me.
