I noticed that my rims have a max PSI of 65 lbs but I have always run at 70-75 psi with Maxxis Load E tires. I run at 70 psi because the trailer has a max weight of 11k lbs. Should I be concerned ab...
I've thought about running higher than "E" on my TH; it's a 6 lug and those tires are made for 8. After reading through this, I'm thinking it would be safer to just convert to an 8 lug hub and get the proper wheel and tire combination, maybe a 17.5.
