EyetattooExplorerJul 05, 2013Max rim PSII noticed that my rims have a max PSI of 65 lbs but I have always run at 70-75 psi with Maxxis Load E tires. I run at 70 psi because the trailer has a max weight of 11k lbs. Should I be concerned ab...Show More
64thunderboltExplorer IIJul 15, 2013I always run the trailer @ max psi.I have some of the so called China bombs with about 4300 miles on them and all is good so far. E rated 3520# @ 78 mph.I have heard all the BS so don't start. I knew what I was buying .
Related ContentRim max PSImax tire psi vs door panel max load psiE rated tire with max psi of 65?Max PSI rating on Trailer Wheels?PSI
