Eyetattoo
Jul 05, 2013Explorer
Max rim PSI
I noticed that my rims have a max PSI of 65 lbs but I have always run at 70-75 psi with Maxxis Load E tires. I run at 70 psi because the trailer has a max weight of 11k lbs. Should I be concerned ab...
64thunderbolt wrote:Normally I would but I got concerned when I noticed the max psi stamp on the rims that said 65 psi. Just want to be sure it is set up properly before we head out this Friday.
I always run the trailer @ max psi.
I have some of the so called China bombs with about 4300 miles on them and all is good so far. E rated 3520# @ 78 mph.
I have heard all the BS so don't start. I knew what I was buying .
