I noticed that my rims have a max PSI of 65 lbs but I have always run at 70-75 psi with Maxxis Load E tires. I run at 70 psi because the trailer has a max weight of 11k lbs. Should I be concerned ab...
Thats what I thought. They have been on this TH for roughly 6 years with no issues but my parents used to use D rated tires. I replaced the old tires with new E rated ones and then noticed the psi rating on the rim. Just trying to figure out what pressure to run. My max weight on the TH is 11k lbs.
