jadatis
Feb 05, 2015Explorer
ipeltier wrote:
I have Maxiis radial M8008 load range D tires on our fifth wheel. The Rv loaded weighs around 8500 lb. Does anyone know what the psi should be?
Can you give sises of tire or maximum load and speedcode of tire, then I can calculate a pressure range for your.
But your estimation of the load is dangerous, in practice it prooves to be higher mostly then you think. Only way to be shure is weighing , and then best per tire , second best per axle.
Also need configuration , so number of axles and total number of tires on the road.
If you only weigh total weight , I can determine a weightdifference to use, and make a pressure loadcapacity list for different speeds , and filled in with determined minimum and maximum load per tire.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
