laknox
Feb 05, 2015Nomad
azdryheat wrote:
But if you over inflate the tires they will wear prematurely in the middle and wear out sooner. I took my trailer to the scales and found out how much weight is riding only on the tires and use that to figure the PSI (13,025 in my case). I can then figure the weight and PSI when I put toys in the garage and adjust the tire pressure accordingly.
When was the last time an RV tire "wore out", that wasn't from having bad axles/hubs? I've run my E-rated tires at 80 and 70, and there's almost zero difference in "contact patch" at the same weight. I can't tell any difference in ride, either. Unless I were completely empty, and making a multi-thousand mile trip, I'd just keep 'em at max psi and not worry about it.
Lyle
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
