RustyJC
Feb 07, 2015Explorer
tinner12002 wrote:
I run my Maxxis 16" tires at 10 under max psi, one reason because I have more tire than came on the RV and 2, because pres increases as you start rolling down the road so in hot weather they still sometimes get over the max pres but not enough to worry about.
The maximum pressure shown on the sidewall is the maximum COLD inflation pressure. The manufacturers know that the pressure will rise above this max pressure as temperature increases - that's allowed for in the rating. The 17.5" Goodyear G114 tires on our 5th wheel will go from a cold pressure of 120 PSIG to a "hot" pressure of 135-145 PSIG with a tire temperature of only 95 to 105 degF.
Rusty
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
