rtaylor0830 wrote:
Are the maxis st tires any better than the rest. I have 230/80/16 tires now and I don't think I can go to the 235/85/16 due to clearance I have blown power King and marathons I am trying to find a good tire if there is one. I only have about 2 inches of clearance above these tires now.
Not really as we have had around 30 members with Maxxis ST 8008 issues which is about the norm on other rv and non rv trailering websites.
Many folks upgrade to a LT E tire at 3042 lb capacity on trailers with 6k axles and smaller.
For 7k axles and maxed out 6k axles the ST 16" Sailun S637 G load range at 3750 lbs has been a winner.
If we knew what your trailers GVWR and 6k or 7k axles and gross axle loads we can give you a good idea on better tire selections for 7-8 years and 40k-60k miles.
