Paul Clancy wrote:
Me Again wrote:
Paul, there are 16" LT's in 215/85R16E that are 30.39" in diameter. They are rated to 2680 each and would be a good fix for your lighter weight.
Bridgestone Duravis R250 all steel or R265 2 ply poly carcass.
Or
Michelin XPS Rib
6-8 years of trouble free trailering, and you will not wear them out.
Chris
Both too wide.
:h
How can 215 be too wide when you are currently running 230's?? The tread width is measured in Millimeters, a millimeter is a millimeter, those tires are 15 millimeters narrower than what you are running!
