rhagfo wrote:
Paul Clancy wrote:
Me Again wrote:
Paul, there are 16" LT's in 215/85R16E that are 30.39" in diameter. They are rated to 2680 each and would be a good fix for your lighter weight.
Bridgestone Duravis R250 all steel or R265 2 ply poly carcass.
Or
Michelin XPS Rib
6-8 years of trouble free trailering, and you will not wear them out.
Chris
Both too wide.
:h
How can 215 be too wide when you are currently running 230's?? The tread width is measured in Millimeters, a millimeter is a millimeter, those tires are 15 millimeters narrower than what you are running!
I've looked at the Lt option before but maybe thinking of a different size. Regardless the capacity is too close for my comfort. The maxxis are in and March 2016 mfg date so that is the choice for this go round. Thanks for the options though.
Cheers
Paul
