CaLBaR
Feb 07, 2021Explorer II
MFL wrote:
Not sure why you are measuring to the GN ball, but your Ford will have several more inches of clearance, than the Ram, measuring from back of cab, to axle center.
A FW, weighing 14,500 empty, will be 16K+ when loaded. That is getting to the limit of a SRW. Yes, the springs are different between the 25/35.
Some hitches work better than others, when using a truck with a 6.4/6.75 ft bed truck. Lots of options, so do your research, or ask more questions here.
Jerry
I think the OP is using this measurement to indicate that he will have enough clearance with the RAM when compared to the Ford. This will be accurate especially if he is going to use something like a Reese Goosebox. Gooseball location relative to the cab should also be a good indication of the distance to the rear axle.
Rob
About Fifth Wheel Group
