cummins2014
Feb 07, 2021Explorer
MFL wrote:
Not sure why you are measuring to the GN ball, but your Ford will have several more inches of clearance, than the Ram, measuring from back of cab, to axle center.
A FW, weighing 14,500 empty, will be 16K+ when loaded. That is getting to the limit of a SRW. Yes, the springs are different between the 25/35.
Some hitches work better than others, when using a truck with a 6.4/6.75 ft bed truck. Lots of options, so do your research, or ask more questions here.
Jerry
What is your measurement to axle center , I'm thinking where one wants to measure is about half way up the rear window, thats about where at the minimum these newer fifth wheels are going to make contact. About any dent in the cab itself I have seen ,it seems like they are fairly high up on the cab.
About Fifth Wheel Group
