cummins2014
Feb 07, 2021Explorer
MFL wrote:
cummins 2014, and OP, my rear axle center is 41"s behind the cab of my F250 with 6"9" bed.
I measure from hitch (pin center) keeping tape level to back of cab, below window glass. I am back 40.5 inches.
I have seen broken windows, as well as dented cab corners. With the newer rounded FW fronts, it is a game changer! However, if you are unaware, don't pay attention, think you need to back to 90 degrees, you will likely have an issue. No different than a TT, enclosed utility trailer, even a boat...if you are unaware, distracted, you can cause damage.
Jerry
Well, I get right at 40" center of axle, about half way up on the window on my Ram, down where I suspect you are measuring a good honest 38.5" . It seems where I loose the most is behind the axle . If I remember my ford was 6'-9" this Ram is 6'-4" . It appears on my puck system that gooseneck ball hole is 37.5" right at 1" forward of axle center. Maybe some other Ram owners ,can verify that. I didn't get out a straight edge or level . :)
About Fifth Wheel Group
