dustinlExplorerJan 11, 2020melting plugin the past 14 months i have had to replace the 30A plug that plugs into the rv parks box at least 3 times because 1 of the prongs overheats and melts my plug. need ideas on what might be the cause
time2rollNomadJan 11, 2020Are you replacing just the end or getting a new cord with premoulded end?In general I think the replacement ends are better.I recommend this one:https://www.progressiveindustries.net/tt-30pAlthough poor connection in the worn and corroded outlet is often the issue.
Related ContentSuburban SW12DEL Water Heater On/OFF switch melts???power cord plug melting7 pin plug amperage rating?Melted plug prong - would you use it?NEW, 30a plug starting to melt
