dustinlExplorerJan 11, 2020melting plugin the past 14 months i have had to replace the 30A plug that plugs into the rv parks box at least 3 times because 1 of the prongs overheats and melts my plug. need ideas on what might be the cause
smartyExplorer IIJan 13, 2020Have you checked the rig itself to see if it is "Hot"? You may have some sort of short that is drawing excessive power.
Related ContentSuburban SW12DEL Water Heater On/OFF switch melts???power cord plug melting7 pin plug amperage rating?Melted plug prong - would you use it?NEW, 30a plug starting to melt
