dustinl
Jan 12, 2020Explorer
melting plug
in the past 14 months i have had to replace the 30A plug that plugs into the rv parks box at least 3 times because 1 of the prongs overheats and melts my plug. need ideas on what might be the cause
ScottG wrote:
It's sad but the industry's NEMA TT30R/P design is really under engineered IMHO. Many decades ago when it was created, there were no electric water heaters (in RV's) or micros, TV's, large battery chargers, etc. Just some lights and the occasional space heater. Then add in poor quality, off shore parts and it only gets worse.
We use a lot more of the capacity if these "trailer" circuits now and while they work OK when everything is perfect, they don't like running a constant load at anywhere close to their 30A rating.
It's too bad we can't switch over to the marine undustrys 30A receptacle for pedestals. It seems to hold up better.
OP has not been back in like 8 days, if same park, bad pedestal outlet. Different parks likely too much draw.
smarty wrote:
Have you checked the rig itself to see if it is "Hot"? You may have some sort of short that is drawing excessive power.
