ol Bombero-JC wrote:
Cummins12V98 wrote:
SeniorGNC wrote:
Well, I never expected to be writing this but I had a blowout on my second set of Michelin 16” LT load range E tires.  They were only a year old.
We were on our way back to Houston Tx a week ago from a long summer vacation loop through the southwest desert.  (About a 3000 mile pull.)  On the last day just a couple of hundred miles north of home on US 84 we lost a tire to what the tire store manager called a catastrophic blowout.  (There were just some inner casing pieces between the beads.)  This was during the heat wave, I think the outside air temperature was about 103 degF.  I pull at 60 mph, checked my tire pressure in the morning as I started and thought I was good.  All that came to an end when a car pulled up next to me and held up a sign saying “blowout”.  Bummer.
I could not even tell I was down a tire.  There was no indication based on handling.  Last time I scaled I was about 8600 lbs total on the two 5200 lb trailer axles.
Now I don’t feel so invincible tire wise.  It cold have been due to a bad tire, a leaky valve stem, road hazard, who knows?
Maybe it is time for RIBs on the trailer and a tire pressure monitoring system.
Good thing I carry a tire changing ramp and DOT triangles.
Oh well, time to go fix the damage to the trailer…
FYI, if they were GoodYear tires they would have paid for the damages.
FYI (Goodyear Tires) = *maybe* they would have paid..:W
Check the down time to trailers.....GY -vs- Michelin.
GY wins hands down (tread off?) for amount of down time..:R
Never had any down time with Michelins.
No problems, no failures, no repairs required = no down time..:C
GY is another (bad karma) story..:( - (Including G614s)..:(
"Stuff" can happen with any tires -  but I'll stick with Ribs!
FE has it right -and- should have added, slow loss of pressure will certainly cause increased heat.
A good TPMS *should* give warning of decreasing pressure in advance of failure - before it becomes catastrophic.
I'm on my 4th set of GY tires, one E Wrangler, two G6114 G and one G114 K never even a flat.
I use Michelin's on my vehicles but stick with GY's on my RV's.  Yes the GY G did have problems a few years back.  My Dad had two or three tires blow and GY stepped up and paid damages and replaced tires no questions asked and in the last 7 years or so he has not had any trouble at all.
Much better than a claim on your ins co.
