Hunter4593 wrote:
Me Again wrote:
6 XPS Ribs at 3042 each provide for 18252 lbs of capacity on the axles. What is the GAWR?
The Bridgestone Duravis R250's or M895's are cheaper and as good as the Ribs.
Do you have at least 33" center to center on the axles for LT235/85R16's, if not look at 245/75R16's. With three axles G614 might be an overkill, and they are VERY expensive.
You are wise to dump the ST's!
Chris
GVWR is 18000. Will check Center to Center measurement today. I do know that space between tires is tight so may have to look at the 245/75/16.
One of the new twists I’ve recently encountered with light truck tires is a warranty provision disallowing coverage for LT tires used in misapplications.
Here is a link to the Michelin Standard Limited Warranty.
Click hereIf you call or eMail Michelin of North America and give them the tire information off your trailer’s certification label I’m sure they will not recommend the XPS Rib to replace those tires.
There are other options in 16” sizes and many more in the 17.5” sizes. Many of the 17.5” tires are medium duty truck tires designed for low profile trailer service and will have higher speed ratings than the ST tires.
FastEagle
