- barney_bugleExplorerTwomed thanks for the link and all the other responders thank you . Am going out searching now thanks again everyone
- barney_bugleExplorerYes rhagfo it is.
- TwomedExplorer
- rhagfoExplorer III
barney bugle wrote:
My old one is metal on the bottom with charcoal filters and is open on the bottom( boxed in on top and sides only) so I'm worried about the heat from the range if I just put a counter top in place
So you have a combo micro and vent? - barney_bugleExplorerMy old one is metal on the bottom with charcoal filters and is open on the bottom( boxed in on top and sides only) so I'm worried about the heat from the range if I just put a counter top in place
- DutchmenSportExplorerI replaced the microwave in our Springdale. We found a good match (not perfect, but close enough) at Wall Mart. I drilled holes through the shelf base and ran screws into the feet of the microwave where they screwed into the base of the microwave. I then took the trim off the old microwave and was able to Jerry Rig it to make up the gap. When done, it looked factory installed. We really liked that microwave too, it was red and pretty!
barney bugle wrote:
They only have household ones 30" wide.my old one is only 24" wide and mine is over the range so a counter top won't do.
Have you looked at your old one? Replacing with a 24" counter top unit is likely the perfect replacement. - barney_bugleExplorerThey only have household ones 30" wide.my old one is only 24" wide and mine is over the range so a counter top won't do.
- midnightsadieExplorer IImeasure your old one and go to wal mart and pic one out. thats what we did.
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 28, 2025
