fratedog's avatar
fratedog
mini and motorcycle
What toy hauler would be capable of transporting both a Mini convertible and a 500 lb motorcycle? All suggestions welcome... except for the 7 figure crazy German rigs!! tia, fg
  • Another thing to consider is ramp angle, with the mini as low as it is you might have a tough time cresting the top.
    Also check the weight limits of the ramp, the garage and overall CCC.
  • I would think you're going to have to find a dedicated car hauler with living quarters. Depending on the configuration of your Mini, you'll be pushing the weight limits of the ramp door that come on most of these mainstream toyhaulers.
  • The mini is about 12.5 feet long, plus a bike. You are going to need at least a 16 foot garage area if you are able to swing the bike around sideways.. There are a couple manufacturers with garages that length, KZ Venon, GD Momentum, XLR Nitro 39DKS5,Work and Play 40WCH ,417AMP XLR thunderbolt ,Heartland CY4018,Road Warrior RW418,Fuzion 416,Voltage 3818 to name a few. Good luck in your search.
  • Bedlam wrote:
    We went to a truck camper with enclosed trailer in tow that can do the same. If you're looking for larger living space a Super C or Diesel pusher can tow an enclosed trailer.
    This might be your best bet.....and maybe the only practical option.
    This allows you some flexibility with the living quarters, to change when your wife gets tired of the first layout.
    A self contained A that can do what you want might cost more than your house......even a used one.
  • There are many car hauler enclosed trailers with living quarters that could work: Work and Play, InTech, Millennium, Feather Lite.
