b_pilot's avatar
b_pilot
Missing a/c return air grill
I have a Lifestyle 5th wheel made by Evergreen RVs. The two a/c units are mounted on top of the camper and have ducts that run down both sides of the camper to distribute the air. There is a return air vent in each of the ducts. One of the grills that holds the air filter in place fell out with the vibration of traveling. It must have fallen on top of the slide out and then was pushed outside when the slide was put out. Anyway, it is gone, and I need a replacement. Can't go to Evergreen as they went out of business several years ago. I have checked the internet and some of the local parts dealers around here. Does anyone have an idea of where I should look? The air return vent is 6x12 inches. I have to find something so the filter will stay in place.
  • My a/c is an AIRXCEL which is coleman. The air return is not a part of the a/c unit. It is a ducted system with the return air vents separate from the a/c itself.
  • I'd check a local RV parts store, those a/c units are standardized. I needed the inside filter hold and went to the local shop they had a whole big box full of them, apparently a common replacement part.
  • What make air conditioner do you have? As far as I have seen, all trailers and motorhomes with air conditioners have the return air as part of the conditioner itself (actually, it is part of the ceiling cover but contains the filter). It should be available at just about any RV place or on the internet.
    Barney
    Does yours look like this?
