Cummins12V98
Jul 25, 2015Explorer III
shadows4 wrote:Dave H M wrote:
After all that theory, I bet you are going to be on edge for the upcoming trip. :h
I don't disagree with all the theory here, however I am assuming you wiped the races clean and made sure they looked good. If so i would go with the following advice:
I would monitor hub temps with a IR thermometer though.
It's not like the $15/axle bearing sets were run in at the factory to match the rollers to the races. They just get a cage out of one bin, a race out of another and wrap them up together.
I use my paws instead of the IR shooter.
If all feels god after the run in of 100 miles or however you want to use as a yard stick, you should be good to go.
Oh and don't forget to let us know that the trip went well, so all of us theory folks can immediately come back and say you were lucky.
Thanks Dave for bringing some sanity to this thread. I thought I did something right but I guess I only did it half right. I know that the races should really be replaced at the same time, I was just trying to save a couple of bucks. I will do as you advised and monitor the bearings.
I was happier that I found the cut wires and repaired them than the bearings.
Believe me, the next time I do a service on the bearings I will replace all with Timkens. Oh and I won't metion it here. Thanks for all the replies, John
Maybe I should have titled this thread "Mission half accomplised!!!
I don't think anyone was criticizing YOU for what you did. You obviously thought you did the right thing.
Personally I think the parts place should have advised you to just replace the seals and re use the bearings if all the bearings looked like the one you showed the mechanic.
i think the comments on this thread were good info for those that really don't know about these things and I am sure some novices appreciated the comments.
Don't loose any sleep over it!
About Fifth Wheel Group
19,042 PostsLatest Activity: Apr 15, 2026
