Coach-manExplorerSep 26, 2014Mixing battery typesQuestion for the battery "Gurus", what is the downside of mixing a gel cell with a standard wet cell type? Will I risk overcharging one or the other? Feedback and comments would be appreciated.
time2rollNomadSep 26, 2014Alternator initially charges at about 14.5 volts and will do far better than most converters that are fixed at 13.6 volts.Compare amp hour ratings if you want to keep the lights on. AGM is superior at starting and I recommend Sears Platinum for start AGM.
Related ContentMixing battery types??Is it OK to mix battery types??Mixed Tire TypesMixing oil types (5w-20 mixed with 10w-30)Mixed Messages
