Old-Biscuit
Sep 17, 2014Explorer III
fj12ryder wrote:
Maybe if your legs are lubed very well you may be able to lift them if not lifting straight up. Mine simply will not go up unless I'm lifting straight up on the leg.
I agree that pulling to the side while trying to lift up will cause the leg to bind. But like I said it may work if the inside of the leg is well lubed.
I use a dry graphite spray lube on my legs and stabilizers (and just about everything that needs lubed).
Inner tubes slide smoothly. I use my awning rod....just slip end into lower pin hole and pull up. Easy-peasy
About Fifth Wheel Group
19,031 PostsLatest Activity: Apr 14, 2024
