Hardscrabble
Mar 14, 2022Explorer
Truck modifications
Hi all,
An update from the road. When I got this rig (2019 Silverado 3500HD and Northern Lite truck camper) the only suspension modification I put on was Torklift Stableoads. We traveled for about 15k over 3 months and while it was okay, I knew it could be better. Some sway and although the truck handled some back trails and high winds, it just felt like it could be better. The stock OEM shocks were about the same - okay but just had trouble keeping up with the "rebound", settling out the ride after a bridge expansion joint (a pet peeve of mine, are we just not able to smooth that out?) took longer than I liked and they just seemed a half step behind. Also, the OEM Wranglers were noisy, and just did not have the grip and ride I want.
Covid happened. Our plans were sidelined. Life....
We are lucky enough to be able to return to roadlife but I knew that I needed to make some changes. After much research, (some of it right here, thank you all who contribute your knowledge and experience), I changed the tires to the Michelin Agilis Crossclimate, did that last winter as the Wranglers sucked in the snow/ice. They were a significant improvement, quieter, better grip, more "solid" and much better winter tires. I then replaced the OEM shocks with Bilstein 4600s - again significant difference (better) with the truck camper off. I then installed the Timbren severe duty bump stops, as they do not touch unloaded, no change with the camper off.
Put the truck camper on and drove 1,300 miles in three days, brutal traffic at times, gusty high winds, snow, snow squalls, terrible roads (it is like a 3rd world country in places) and a wide variety of situations. I can say that all the modifications made a significant improvement to the ride, the handling and overall driving experience. The shocks dampen the ride with authority, they "keep up" and recover stability quickly. The Timbrens are significant as well, with the camper on before them I was 1/8" lower in the back, not bad at all but now, I am 1/8" higher. The sway is gone. I can feel the weight obviously, but going over uneven pavement, up into driveways or driving in 25 mph winds that were a direct crosswind, gusting to 35 - completely different and better. The tires are sure and very trustworthy.
I am not a paid endorser for anything. All opinions are mine and your results will vary. I just wanted to provide some feedback from my situation and try to pay it forward in exchange for gathering a lot of great information on this forum, thank you contributors!
Regards.
Regards.
[/img]
