Dayle1
May 12, 2017Explorer II
Denali2015 wrote:
Thanks you for your comment. If it is dry on top of the silver bubble wrap,when I take it off then maybe it's safe to assume it's from rain intrusion...
The silver bubble foil is probably not continuous so a water leak at one spot could run on top of the foil then drop thru at a joint and end up at the lowest point of the coroplast. So just because the top is dry in one spot that does not rule out a water leak elsewhere.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
