swift1972's avatar
swift1972
Mold already??!!!!
Hi there- well we found a huge problem. Mold in our 2013 camper that we have had for 1 year. I'm beside myself right now. We take wonderful care if our fiver. I can't believe this is happening. So I discovered these weird little hard spots next to the door.
We spoke with the dealer described the problem.took photos sent the to the dealer and it is mold. They contacted jayco and we are getting it repaired- waiting for parts. So- we figured might as well go camping as planned this week. We get to the site and I'm getting everything unpacked and low and behold- all along the back end of the fiver is mold spots. Wth!!!!!! We have done nothing to this camper- as far as any work to it-it's in brand new condition besides this- no visible leaks. And this mold I just discovered was not there 2 weeks ago when I last looked. When we saw these mold bubbles forming I went thru the inside of the camper many times running my hands over every inch of the walls. We called the dealer today with the new problem- they said call jayco- we did- no call back yet. Should we e expecting mold in a basically brand new camper???? I would expect it after say 20 years- but a year??? Any advice in dealing with this issue?
- yes we use a dehumidifier all the time even during winter.
  • Another source of humidity to consider is using the propane stove without venting to the outside; range hood, door open, etc..
    Burning 20 lbs of propane will produce 30lbs of water... It's got to go somewhere. Living up here on the west coast, we are very aware of this.
    r
  • Is it possible for you to post a picture on here? I am very curious to see what this mold looks like.
    good Lcuk!
  • Trackrig wrote:
    I know a person who bought a new MH. The next spring when they went to use it, the cupboards were full of mold. They fought the mold for most of the summer. As it happened the factory didn't seal either air conditioner correctly and they leaked a lot of water into the ceiling. Their insurance totaled it.
    Bill
    The manufacturer should have replaced it, no questions asked.
    Lyle
  • BB_TX wrote:
    You should NOT expect mold in a one year old trailer.
    With that much mold I would be asking them to replace it. No way are you, or they, going to get that mold out without basically tearing it apart and replacing a lot of materials.
    Jumping the gun here dont ya think?
    Many diff reasons for mold and most are easily fixed.
  • swift1972 wrote:
    Once we get to the next campground with (for the PC)wifi. Later today I will try and get some photos up. We live in michigan too- and we have the dehumidifier going all the time even this past winter. The spots where mold are showing up nothing is stores there. It seems like it's coming from the outside in if that makes sense. This is our fifth camper- and we've had a couple of oldies in the past and never had a problem with this. Oh and i forgot to mention that when the hubby called the dealer the tech he spoke with said the same thing was happening with a forest river about the same age. And he said he'd never seen anything like it. I'm so disappointed I love this camper almost more than my house. We are very shall I say anal about taking care of her. We have the max air vents as well. I'm thinking of pushing for a replacement. We did not pay this kind of money to be dealing with this. I also use those damp rid containers too. In so upset- this is my baby and ya know- it was the floor plan I had always dreamed of. When we tented before we got married- I'd see these big fifth wheels with the big window in the back and always said someday we are getting one just like that. Sorry- I need to vent a little- I just want to cry.! We take such good care of everything we have, and I'm just heartbroken over this.
    I understand your upset.
    Wait for a proper diagnosis of the problem.You may be getting upset for no reason.It maybe just mold on the outside walls due to high humidity inside the rv with no mold in the walls...Or maybe not but I would think thats more likely the problem then a roof leak,etc..Most worries in life are for no reason in the end.Just cause unneeded stress.
    That's what I thought too. Mold spores exist everywhere. They are always floating unseen in the air. Basically all they need is the right climate to grow (a combination of moisture and still air).
  • Well, you spooked me, so I went out and checked our 11 yr old 5er that has been sitting all summer - and it's fine. Even in the 70+ degree dewpoints we've been treated to this week (yuck). But I agree with others - somewhere, you've got a wet spot that is creating the perfect indoor environment to grow mold?
    My pontoon boat gets mildew due to a non-breathable cover - I use a product called X-14 to clean it and kill the mold - but keep in mind that most mold-killers contain bleach. Be very careful where you spray it!
  • is there anything that we should be doing as a preventative measure to prevent this from happening? keep a vent open and/or use some damp-rid?
    I have seen enough mold to know that what you see is often the tip of the iceberg. Since it was "all along the back end" it is likely also beneath/behind the associated materials.
  • Do yourself a favor and get this moisture meter, this thing works!
    Moisture meter
    Go along the walls, cabinets and floors with this baby and it pinpoints where all the moisture is centered. This unit can detect moisture between 1/2 to 3/4" below the surface. Don't slide it across the surface lift it as you move it.
    I went through my house with this baby and found one spot beneath a sliding door that was leaking a bit and soaked into the floor, and another spot on the wall of my store room pointing to a leak in an outside plumbing pass through.
    Good luck with your camper.
    Ron W.
