theoldwizard1
Jul 15, 2020Explorer II
patperry2766 wrote:
Wife and I like the G class Momentums, but they use that has a 25 year warranty 1" "marine grade" OSB decking...
That is a BS "marketing term" ! It is 1" because OSB sags moire than plywood.
patperry2766 wrote:
Should I realistically be too concerned with the floor decking material?
jdc1 wrote:
Flooring substrate? It will last forever....if it is never exposed to moisture.
I concur with jdc1 !
If you want a real water resistant floor, it need to be 3/4" honeycomb with fiberglass on both sides. Yes, $$$ !
IMHO, the best roofing material is COMMERCIAL GRADE TPO (?60 mil). All seams and edges must be first reinforced with TPO flashing tape. Any roof protrusions need to be mounted on "curbs" raised up above the roof surface and flashed with pre-formed TPO. TPO is "heat welded" together. Again, $$$ !!
About Fifth Wheel Group
