lalt's avatar
lalt
Montana 305 RLS
My DW and myself recently visited a Montana dealership on a snowy and cold day and were interested in looking at a Montana 305 RLS. The sales rep took us outside to the Montana and as we stepped inside the rep said " the Montana has cable operated slides and you will not like the cable slides". So my questions are as follows:
1. What is the down side of the cable operated slides?
2. When did Montana start using the cable operated slides?
3. Are operating a cable slide in snow and cold weather not advised?
So I am interested in what you the owners or previous owners of cable operated slides have to say on the subject?
The sales rep ended up showing us a Grand Design Reflection instead of the Montana. So what's everyone opinion on comparing the two units? We will be going to the RV Super Show in Cleveland in Jan and will look at the Montana brand from a different dealership.
Thanks in advance for all of your comments as I have learned a lot from you fine members of this site.
  • I purchased a 2013 Montana High Country 318RE in March of last year trading in a 2010 Sprinter TT. The Sprinter had a gear driven slide out and performed flawlessly for the nearly three years that we had it. The Montana has the cable slide outs and after a full season of use the cable system has performed flawlessly. The main difference beside one system is gear driven while the second system is driven by cables and pulleys is the weight between the two system. The dry weight for the 25 foot TT had a shipping weight of 6,284 with the one slide. The Montana had a shipping weight of 9,183 with three slides and 34.5 feet nearly 10 feet longer. Simple physics states that the heavier the load the greater the fuel consumption. However, aerodynamics also is a major factor. Though towing nearly 3,000 pounds more my fuel consumption has decreased. Weight therefore is the primary difference weather could have a minimal affect since the cables are exposed to the elements ice and snow, rain however would not be an issue. If however, I had a slide stuck in the open position because of a motor failure the cable is easier to access to manually retract the slide. Just make sure you have an electric drill to use the retraction tool. Another thing to consider is the weight difference between the two 5vers both shipping weight and pin weight and then the tow capacity of your tow vehicle that should be your deciding factor .
