goducks10
Sep 04, 2014Explorer
6000lb axles on the Big Horn means you could be at your limit. Not sure if there is an option for 7000lb axle. Dry weight at 12,000 with a 2100lb pin means that you have 9900lbs on the axles before you load anything and that's using brochure weights.
I wonder if it's a typo on the web site since the Big Country 3150RL which is similar has 7000lb axels.
About Fifth Wheel Group
