Old-Biscuit
Feb 13, 2016Explorer III
Two 6V batteries can have higher capacity AH then one 12V IF the 6Vs have higher capacity AH to begin with
Two 6v Batteries wired in 'series' will double the voltage but have same capacity AH
To increase capacity AH requires 'paralleling' of batteries
As for charging......check which Brand/Model of converter you have.
A good 3 stage should be compatible with AGMs
But two 12V flooded are less expensive and can double your capacity AH
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
