laknox
Feb 18, 2016Nomad
Veebyes wrote:
The AGM advantage is not just the zero maintenance thing. They are rated for far more discharge cycles than a wet cell. They also will take a much deeper discharge & recover than a wetcell. During storage the discharge rate is half that of a wetcell. Leave an AGM all winter with no maintenance, no problem. Adding more batterys in a location other than an area intended for wet cells, no problem. Put them in storage compartment under your bed if you wish, no problem.
That would be cool. Imagine, having 100+ lbs over your axles instead of in the front storage locker. :-)
Lyle
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
