Davezogg's avatar
Davezogg
Mor Ryde Pin Box Question
Our new Keystone Hideout has a chucking problem and lots of folks have recommended the mor ryde pin box...
I am very interested in buying one, but I am already riding a few inches high with the hitch at the lowest point and the factory pin box all the way up.
Can anyone tell me if the Mor Ryde pin box would raise the trailer even more???
The axles are under the springs so flipping is not an option....already there.
Thanks in advance
  • rhagfo's avatar
    rhagfo
    Explorer III
    Thanks in advance
    Before spending $700+ on a pin box, take a good look at how you are set up.
    While nose high is not a good thing, lets put that last on the list for now.
    #1. What is your percentage of pin weight? Requires a trip to the scales. 1st trip through with 5er in tow, get TV front, TV rear, and trailer axles. Then drop the 5er and scale the TV again TV front and TV rear.
    (TV loaded front + rear) - (TV unleaded front + Rear) = Pin
    Pin + Trailer axles = 5er total weight
    then pin/5er total weight = pin percentage
    Your pin percentage should be at least 20%, if less could be part of the chucking issue.
    #2. Shocks!
    Does your TV have great shocks? Bilstein's Rancho's or similar?
    Does your 5er have shocks? If not watch it the next time you hit a bump in the road, if it bounces more than once, shocks would make a difference.
    #3. Nose high, just how nose high is your 5er, 2", 6' or more?
  • Most of the cushioned pin boxes are designed as a replacement for your specific stock pin box. My Demco Glide Ride was and MOR/ryde, Lippert and the others should be the same. My Glide Ride put the pin in exactly the same position as the stock pin box that came off. MOR/ryde should be able to answer your question for you. Just give them a call with the manufacturer and model number of the stock pin box on your trailer. Keystone uses Lippert frames, so you should be able to find the pin box model on the pin box and get and a good replacement. Be sure and get a cushioned pin box designed for the weight of your trailer - it's important so the ride isn't to stiff or too soft.
    Rob
