Gib3633
Oct 30, 2013Explorer
IS suspension is the best money Iv'e spent since getting involved with an RV. It takes two days of labour reinforcing the frame measuring it all up ,fabricating four fixtures installing them and doing an alignment. There has been much talk about the height of new 4x4 trucks being higher than older models. They also take this into consideration when measuring to install the fixtures. When you leave there shop your 5er is perfectly level which gives you more ground clearance at the back end. You wouldn't put this on a 10,000 lb. trailer but I wouldn't be without it on a 15,000 lb. trailer. I,m not saying it was cheap but I will say Mor/yde gave me good value for the money.
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
