ramgunner
Mar 01, 2016Explorer
DOITHARD wrote:lincster wrote:
Carb is gummed up.
400 hours on a genny that is 9 years old equals hasn't been run much.
I have 1100 hours on my genny and my trailer is a 2006.
Put a new carb on and your issues will go away.
Then remember to run it 1/month at 30 min each time.
Had the same problem on my with 1200 hrs. First tried the fuel pump and didn't help next I replaced the carb. Works like a charm now. Also keep a spare fuel pump and carb just in case. My issue came about from not running it frequently and not adding fuel preservative.
Another thing that will help is to locate and use ethanol-free fuel. It helps prevent such issues in things like ATV's, generators, etc.
It's not too hard to find in most areas. Pure-Gas.org and others can help you locate it.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
