mapguy
Mar 06, 2016Explorer
Y-Guy wrote:
See if there is a split in the fuel line or try detaching the fuel line from the pump and run a small line to a gas can with fresh gas and see if you have the same problem. How old is the fuel in the tank? Did you add any stabilizer?
Great idea using portable can with fresh fuel to limit the variables. Also monitoring the hz as the generator runs could give insight on the chain of events happening.
Have you checked for an inline fuel filter. Some toyhauler and Moho builders add them. Also time to inspect the fuel line between tank and generator. Most toyhaulers have a very long run of flexible fuel line. If deteriorating - it could be collapsing during operation from the suction.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
