VetPartTimer
Mar 06, 2016Explorer
Thought I made some progress today, but in the end . . . denied!
I had put the carb/governor spring on incorrectly when I first took the old carb off. So I fixed that and other than the gen starting very poorly, everything seemed to be working good. I turned on the AC1, AC2, micro and TV multiple times in random order. Gen took everything I could dish out. So I thought having the spring incorrect on the governor was the problem.
Starting was still rough though. Cranked and cranked, sputtered a bit and then started and was good.
Decided to test with some fresh gas - pulled the gas line and put it in a jar of fresh gas. Ran for about 30 min that way, no change. Starting still very rough.
Reconnected the gas line and let it sit for a while. Starting still rough, but now it stuttered and stalled out when putting just 1 AC on.
So I'm back to square 1. Got a code 14 this time instead of 13.
I'm wondering if the valves are out of tolerance and if that could be causing the poor starting and stall when applying load.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
