gitane59
Jun 30, 2013Explorer III
Has anyone removed the pin box completely and measured the spacing of the holes and dimensions from the edge of the metal on each side plate of the MorRyde pinbox. If the holes are equally spaced and dimensioned and are equal on each side of the MorRyde pin box then you need to measure the same spec's on your fifthwheel's frame extension onto which the pinbox mounts.
Maybe the original manufacturer of the fifthwheel got something wrong and "adjusted" the original pinbox to compensate.
Maybe find an independent commercial trailer repair shop to investigate. RV dealers have business relationships with suppliers they quite often don't like to ruffle.
From the posted pic's the holes are lining up. :R
Bottom line that ain't right :E
About Fifth Wheel Group
