jimwooster's avatar
jimwooster
MorRyde pin box
Our new Montana came with the Moryde suspension, but not the pin box. We don’t tow nearly as much as we did (all over the US) mostly a trip from Ohio to Key West and back. Snowbirds. Dealer said we could put on the Moryde pin installed for $800.00. If we were traveling like we did with our 2007 Jayco Designer it would be a no brainer. What is you opinion on spending the $$ and upgrading it. Thanks, Jim
  • I just bought a 2019 montana high country 374fl. it came with standard pin box pulled it 10 miles then ordered moreryde pin box
  • I put an Morryde pin box on my trailer and had clunking sound stopping and starting.. Found the 8 nuts on the the rubber spring mount studs was not troqued properly. . Torqued the nuts to 40 lbs and all is well
