schlep1967 wrote:
I don't have them but I will likely end up with them. Only because the manufacturers are forcing them on us. With this style of step they have more options for door location since they do not have to build a box below floor level to store the steps. They can now put the steps above the axles. Which makes it impossible to replace them with the Torklift steps because there is now no box to stow the Torklift steps in.
My concern was the situation where you can not get the steps down level due to terrain. If you can not fully deploy the steps, you can not close the door.
Friends of mine ended up in this exact situation for an overnight stop and had to pull the steps in while they were inside. I'm still not quite sure how they did it.
Torklift has the GlowStep Up-rising steps that are the answer vs. the MorRyde and Lippert solid steps:
https://www.torklift.com/rv/glowstep-revolution-uprising
