Buster52 wrote:
I have seen trailers with a generator mounted the rear of the trailer. I was thing of mounting a 4kw Onan that weights around 210 lbs. plus gas tank on my 2002 Thor Tahoe 5th wheel that weights 5000 lbs. My question is will this take to much weight off the hitch? Is there problems mounting a generator on the back of a trailer? I will be using 2, 2 inch receivers to mounting it to the frame so it will secure and be able to be removed when needed. I seen one trailer where they used 6 gallon boat fuel tanks with quick disconnects. Nice idea.
I'd be a bit concerned about adding > 300 lbs to the rear of such a light FW in that it =could= cause a light-pin condition, which will affect handling. Yes, you can counter-weight it by loading "stuff" in the front. You likely wouldn't need much to counter the weight on the rear, though. Only way to tell is to do it and give it a try. I like the idea of using 2 2" receivers, though. Much more strength and stability, IMO. You can buy pre-made generator boxes that would greatly help with security, cleanliness and appearance, if that concerns you. Some nice 'glas boxes and, more expensive, diamond plate.
Lyle
