The big boys sorry guess I should have said Tire Co. for you. Still think most tire problems come from low tire pressure & ride-on will help. Folks say they check tire pressure but not every time they get in there rig. I have had to go the tire shop twice for nails I found because of low tire pressure when I started to take off in morning. Had a blow out once because I did not check after we stopped for lunch & did not check. Being a old truck driver I like to check my tires every time I get in my rig.
Yes some times you do just get bad tires. Look at the post on here how many times do you hear people say they had problems with LT tires & how many ST tires. Do not know if I have heard any one say they had problems with LT tires.
I am not a ride-on dealer but do use it & if you will use it you will have less blow outs. Also along with being a sealant it will also balance you tire.
http://www.ride-on.com/
If you want less tire problems get Lt tires. Check every time you get in your rig or get ride-on. You can still get a flat with ride-on but I have not to date.
red
